Compact Load Cells Monitor Static or Dynamic Forces
December 1, 2008Comments
Baumer Ltd., Southington, CT, has introduced DLRx load cells, designed to measure force in harsh industrial environments. Featuring IP65/IP67 protection
Offering ideal transverse sensitivity by compensating for noncentrally applied forces, the load cells offer accurate force absorption and precise, low-noise dynamic signal processing during all measuring applications. These sensors can be used to measure compression and tension/compression over the entire conventional force range of 0.5 to 100 kN.
Baumer Ltd.: 800/937-9336; www.baumerelectric.com/usa
See also: Baumer Electric
There are no comments posted. Sensing/Electronics/IOT
June 13, 2023
Rockwell Issues State of Smart Manufacturing Report: Automot...
June 13, 2023
Monday, April 1, 2024
Balluff Launches New Online Customer-Support Capabilities
Jim Finnerty Friday, March 29, 2024
Pairing Sensor Types with the Problems They Address
Wednesday, March 6, 2024
AI-Powered Chatbot for Manufacturing Monitoring and More
