Software for Manufacturing
Benefits of 3D Die-Design Add-On Software
Saturday, December 1, 2007
Article submitted by Raymond J. Proeber, president of Accurate Die Design, Inc., New Berlin, WI, describing his company’s use of add-on software for 3D solid modeling. The design firm also is the U.S. Technical Center and distributor for Logopress3 die-design software.
In 2002 we jumped into the world of 3D solid modeling. It soon became apparent that we had desperately missed all of the tools made possible through the use of a die-design add-on package for our 2D CAD software.
Fortunately, in 2003, new SolidWorks add-ons hit the market, geared toward die design. We selected Logopress3 for our die-design business.
So what does a die-design software add-on bring to the mix that a raw 3D modeler, such as SolidWorks, does not? Foremost, the ability to accurately unfold 3D-modeled parts, regardless of the CAD software used to model them, and regardless of whether they have gussets or ribs running through the bends, varying material thicknesses, etc. The unfolded or flattened part allows the designer to create, within minutes, a strip layout. And in seconds users can modify the strip layout—changing the progression or stock width, or adding or deleting a station or a part in the strip. Just return to the original part after having created the strip layout and apply partial bends or overbends, for example, and watch the strip layout update automatically.
Recently, I demonstrated to designers how a multiple-stepped round drawn cup could be processed in seconds, with each intermediate draw completely and accurately defined.
The strip layout created via the add-on software quickly can be inserted into a die-set template, and because most 3D CAD software is parametric, the size of the die set can be adjusted easily around the strip layout. Parametrics also allow the software developer to create an entire library of guide posts, bushings and other die components in spreadsheets. So die designers need not organize components nor build large libraries of solid models, nor access websites of die-component suppliers.
The organization of die components in spreadsheets and the creation of all necessary holes and subsequent locating of the components are quite transparent to the add-on-software user, as compared to performing these functions via a raw 3D CAD package.
Because off-the-shelf 3D CAD packages are meant to be used by engineers and designers across many fields, they can’t be expected to cut all die clearances through the entire stack of plates in a die automatically—including die taper or step relief—as can a specific die-design add-on software package. Nor can they be expected to manage the insertion and subsequent mounting of form punches in a fluid motion as can be expected with the add-on.
With the die design modeled, the add-on software allows users to enter the press stroke, stripper travel and strip lift, resulting in animation of the strip moving through the die. Meanwhile, the add-on software checks for strip interference or collisions. Of course, during die design is when these mistakes should be caught, not after die build.
Accurate Die Design, Inc.: 262/938-9316; www.AccurateDieDesign.com
See also: Accurate Die Design Software, Inc.
Related Enterprise Zones: Software, Tool & Die
Posted by: Elden on 2/20/2018 1:45:48 AM - URL: http://overigestimuli.tk/sitemap54.php
- Rij van geile huisvrouwen die je worst willen.
Posted by: Jacelyn on 1/2/2018 3:47:12 PM - URL: http://expertdecoders.com/BypassCaptcha-API.aspx
Right here іs the perfect website fߋr everуone whо hopes to understand this topic. Ⲩou realize а whoⅼe ⅼot its aⅼmost harɗ to argue with ʏoս (notthat I rеally would want to…HaHa). You cеrtainly рut a fresh spin ᧐n a topic thаt has beеn discᥙssed for ages. Great stuff, jusxt excellent!
Posted by: Grover on 12/31/2017 8:17:24 PM - URL: http://Expertdecoders.com
Hi there friends, һow іs thе whole tһing, and wһat you would ⅼike to saʏ аbout this piece օf writing, in my view іts in fɑct amazing іn support of me.
Posted by: Hans on 12/31/2017 11:35:10 AM - URL: http://humancoder.com/
Greеtings I am so hɑppy I found your weblog, I гeally found you by mistake, while I ᴡas researching оn Bing forr ѕomething еlse, RegarԀless I am here noᴡ and ѡould јust like to say thɑnk you f᧐r а tremendous post аnd a all round enjoyable blog (Ι alѕ᧐ love the theme/design), Ӏ don’t have time to browse іt ɑll at tһe momеnt but I have saved it annd also included yoսr RSS feeds, ѕⲟ whеn І hаvе time І will bе baϲk to гead mߋre, Pⅼease do keeр uⲣ the fantastic work.
Posted by: Zoila on 12/30/2017 4:33:33 AM - URL: http://humancoder.com/api.aspx
Еveryone loves what you guys tend tօ be սp tоo. Thіs kіnd of clever ԝork and coverage! Keеp up tһe greɑt w᧐rks guys I've aԀded yоu guys tto mʏ personal blogroll.
Posted by: Allie on 12/18/2017 4:38:56 PM - URL: http://captchacoder.com/BypassCaptcha_API.aspx
Ηi thеre, constantⅼy i used to check blog postts heгe іn the ewrly hours in the morning, for the reason that i enjoy tо gain knowledge ᧐f mor аnd more.
Posted by: Shantell on 8/24/2017 9:36:49 PM - URL: https://www.boopinion.com/?option=com_k2&view=itemlist&task=user&id=144270
Should you added AMERICA ONLINE to Internet Explorer, you possess usage of the AMERICA ONLINE search engine and AOL email.
Posted by: Gertrude on 8/15/2017 3:08:44 AM - URL: http://leadingis.co.kr/?document_srl=51782
A Pay - Pal account permits you to email invoices for the commissions and.
Posted by: Tanisha on 8/7/2017 10:00:30 PM - URL: http://www.tripledigitlove.com/love-letter/wwwgmailcom-login-bound-make-impact-your-business
If you aren’t familiar using the Low FODMAP Diet,you'll be able to learn more at. At present though, DSpace doesn't allow one to configure some on the more complex facets of email server configuration like enabling SSL connections, or which.
Posted by: Ernesto on 7/20/2017 7:35:38 AM - URL: http://dutchdrivetribe.nl/index.php?do=/profile-24/info/
If you're a small business or blogger seeking to promote yourself with this platform, the intention of tracking posts on Formspring would be to find out more to do with your customers and potential clients and prove to them that their questions and opinions matter.
Posted by: Consuelo on 6/27/2017 1:18:57 AM - URL: http://www.efli.in/component/k2/itemlist/user/10859
When this approach fails to recuperate the require data users can check out most viable option.
Posted by: Willy on 6/26/2017 11:29:09 PM - URL: http://jerezhoy.com/?option=com_k2&view=itemlist&task=user&id=5037
If you have a very Pay - Pal account, you'll be able to send money instantly to anyone that comes with a.
Posted by: Coy on 6/26/2017 3:02:37 AM - URL: http://www.briant.ro/?option=com_k2&view=itemlist&task=user&id=1962958
If you might be already registered, sign in your account.
Posted by: Carlton on 6/26/2017 2:58:14 AM - URL: http://www.scinese.com/member/samarahavelock/
If you could have a Sony player, press "Home" for the remote, then choose "Network" in the on-screen menu.
Posted by: Tia on 6/24/2017 7:11:02 PM - URL: http://www.olaolorunpooluabitoye.com/tiki-view_forum_thread.php?comments_parentId=10306
Most browsers allow users to place a directory of their favorite sites inside a toolbar within the address and check bars. As you attach a significant document to an email in Yahoo Mail, a loading-style progress bar and an “Adding an attachment” message help you to visually track the procedure.
Posted by: Santo on 6/21/2017 10:37:56 PM - URL: http://megagroup.co.za/?option=com_k2&view=itemlist&task=user&id=20084
Vidimo, da je kupovanje prek spleta res enostavno, iskanje izdelka, ki je najceneji, pa nam ne bo vzelo ve kot nekaj minut naega asa. In the case in our test account it took 37 batches to download all 17,000+ emails dating back to almost several.
Posted by: Clark on 6/21/2017 8:08:43 PM - URL: http://bustlepoint.com/user/profile/12618
If a pal has posted an item that you just want to Share and post in your Profile page having a Via credit, click around the "Share" link beneath item. Identifying real celebrity accounts on Facebook could be a challenge.
Posted by: Ann on 6/21/2017 5:33:34 AM - URL: http://demo64.kerihosting.com/ads/how-4-things-will-change-the-way-you-approach-hotmail-com-log-in/
You have two choices in the event it comes to starting a Hotmail account on the phone. Every Windows Hotmail account features a unique email address and user name.
Posted by: Marjorie on 6/1/2017 12:15:51 AM - URL: http://portaldejuquitiba.com.br/index.php/en/component/k2/itemlist/user/1028
The website will operate a search around the IP address you have given them and offer you the outcome of the location where the IP address descends from, who hosts the address as well as other registration information.
Posted by: Kristi on 5/26/2017 6:40:50 PM - URL: http://levitra-generico.jigsy.com/
Its best to take part in a contest for probably the greatest websites on the web. I will suggest this site!
Posted by: Hildred on 4/23/2017 1:27:32 AM - URL: http://www.myclassified.in/user/profile/3764
The Wii version downloads on the Wii Shop Channel and also the PS3 version through the "What's New" section on the Play - Station Network.
Posted by: Ted on 4/17/2017 5:20:08 AM - URL: http://www.fundrhub.com/out/facebook-nora-aunor/
This can be an article about how exactly to block someone on Facebook. You should hide your Facebook profile through your boss for a number of reasons.
Posted by: Dieter on 3/13/2017 3:27:36 PM - URL: http://goanads.com/user/profile/118
Please let me know if you're looking for a writer for your blog. You have some really good posts and I think I would be a good asset. If you ever want to take some of the load off, I'd love to write some content for your blog in exchange for a link back to mine. Please send me an email if interested. Regards!
Posted by: Otto on 3/3/2017 7:40:23 AM - URL: http://cartraderuae.com.gerbera.arvixe.com/index.php?page=item&id=7
My developer is trying to convince me to move to .net from PHP. I have always disliked the idea because of the expenses. But he's tryiong none the less. I've been using Movable-type on a number of websites for about a year and am anxious about switching to another platform. I have heard good things about blogengine.net. Is there a way I can transfer all my wordpress posts into it? Any help would be greatly appreciated!
Posted by: Genevieve on 3/1/2017 10:33:04 AM - URL: http://keralawomen.gov.in/?option=com_k2&view=itemlist&task=user&id=6276
Hey there! I know this is somewhat off topic but I was wondering which blog platform are you using for this site? I'm getting tired of Wordpress because I've had issues with hackers and I'm looking at alternatives for another platform. I would be awesome if you could point me in the direction of a good platform.
Posted by: Marvin on 2/26/2017 7:48:04 PM - URL: http://www.ssp3forte.eu/?option=com_k2&view=itemlist&task=user&id=27986
I was able to find good advice from your articles.
Posted by: Tyler on 2/24/2017 2:52:36 AM - URL: http://www.fmsl.net/?option=com_k2&view=itemlist&task=user&id=2193
If you've ever switched email accounts, you are aware how annoying it is usually if you've got to re-build your contacts list and.
Posted by: Laurinda on 1/30/2017 7:29:34 AM - URL: http://classifieds.bangkokroomhunter.com/blog/author/alexpalafox/
Sweet blog! I found it while browsing on Yahoo News. Do you have any tips on how to get listed in Yahoo News? I've been trying for a while but I never seem to get there! Thanks
Posted by: Winfred on 1/15/2017 8:19:57 AM - URL: http://divadollhair.com/index.php/component/k2/itemlist/user/1413851
Hi there! Do you use Twitter? I'd like to follow you if that would be okay. I'm definitely enjoying your blog and look forwarfd to new updates.
Posted by: Janeen on 1/13/2017 6:57:06 PM - URL: http://www.ashleyskenya.com/?option=com_k2&view=itemlist&task=user&id=516715
Great blog you have here but I was wondering if you kneww of any message boards that cover the same topics talked about here? I'd really like to be a part of online community where I can get comments from other experienced people that share the same interest. If you have any recommendations, please let me know. Appreciate it!
Posted by: Gisele on 1/7/2017 5:31:22 AM - URL: http://tengotupieza.com/author/carolpfeife/
My partner and I stumbled over here from a different page and thought I might as well check things out. I like what I see so i am just following you. Look forward to looking into your web page for a second time.
Posted by: Ezra on 12/30/2016 2:07:25 PM - URL: https://blog.dew1.eu/groups/what-everybody-ought-to-know-about-american-express-online/
Hi! I know this is somewhat off topic but I was wondering if you knew where I could find a captcha plugin for my comment form? I'm using the same blog platform as yours and I'm having difficulty finding one? Thanks a lot!
Posted by: Carmella on 12/29/2016 7:13:42 PM - URL: http://cbestoffers.com/user/profile/2812
I don't know if it's just me or if perhaps everyone else encountering issues with your site. It seems like some of the text on your posts are running off the screen. Can someone else please provide feedback and let me know if this is happening to them as well? This may be a issue with my web browser because I've had this happen before. Cheers
Posted by: Kazuko on 12/28/2016 5:04:06 AM - URL: http://cms258pro8.ruetten-unternehmensgruppe.de/?option=com_k2&view=itemlist&task=user&id=1532
Hey there! I've been reading your website for some time now and finally got the bravery to go ahead and give you a shout out from New Caney Texas! Just wanted to tell you keep up the good work!
Posted by: Karin on 12/26/2016 3:38:52 AM - URL: http://tvornica-ideja.com.hr/ponuda/item.php?id=20105&mode=1
No matter if some one searches for his required thing, so he/she wants to be available that in detail, so that thing is maintained over here.
Posted by: Lakeisha on 12/20/2016 8:30:23 AM - URL: http://www.bearisland.net/bwca-stories?view=entry&tmpl=component&print=1&id=27822
Hmm it appears like your site ate my first comment (it was super long) so I guess I'll just sum it up what I submitted and say, I'm thoroughly enjoying your blog. I too am an aspiring blog blogger but I'm still new to everything. Do you have any points for novice blog writers? I'd genuinely appreciate it.
Posted by: Rosalina on 12/17/2016 6:05:22 AM - URL: http://unboundtraveller.com/?option=com_k2&view=itemlist&task=user&id=588951
Wow, this paragraph is nice, my sister is analyzing these kinds of things, thus I am going to convey her.
Posted by: Alfie on 12/15/2016 9:47:46 AM - URL: http://www.cmftelecom.com.br/?option=com_k2&view=itemlist&task=user&id=276957
I'm extremely impressed along with your writing talents as neatly as with the format for your weblog. Is that this a paid topic or did you modify it your self? Either way stay up the nice quality writing, it's uncommon to peer a nice blog like this one these days..
Posted by: Isabell on 12/13/2016 9:43:43 AM - URL: http://www.trademarketing.in/user/profile/844
Hello, Neat post. There is a problem along with your site in web explorer, might test this? IE still is the marketplace leader and a good portion of people will pass over your great writing due to this problem.
Posted by: Bess on 12/11/2016 10:09:53 PM - URL: http://www.soulrest.org/?option=com_k2&view=itemlist&task=user&id=1151501
You could certainly see youir enthusiasm within thhe article yyou write.The world hopes for more passionate writers like you who aren't afraid to mention how they believe. All the time go after yyour heart.
Posted by: Krystal on 12/11/2016 12:43:56 AM - URL: http://www.cabinfeverevents.com/groups/outlook-mail-secrets-revealed/
Right now it appears like Drupal is the top blogging platform out there right now. (from what I've read) Is that what you are using on your blog?
Posted by: Booker on 12/8/2016 4:56:52 AM - URL: http://www.shrc.asia/index.php/component/k2/itemlist/user/125709
Hello my family member! I wish to say that this post is awesome, nice written and come with almost all vital infos. I would like to peer more posts like this .
Posted by: Lucile on 12/1/2016 11:59:00 AM - URL: http://www.gfcc.org/groups/slackers-guide-to-paypal-com-login/
For most up-to-date news you have to go to see internet and on web I found this web site as a finest web page for hottest updates.
Posted by: Lon on 11/12/2016 11:43:34 PM - URL: http://hotelsnearme.website/
Hello, i think that i saw you visited my weblog thus i came to “return the favor”.I am attempting to find things to improve my site!I suppose its ok to use a few of your ideas!!
YOUR NAME *
EMAIL *
WEBSITE
